Dual Monitors-messing up programs
raoul_1101
ecently i set up dual monitors on my system. all was going well until i tried running Age of Empires III. Upon startup of the program, i get an error message saying that direct 3d failed to initialize. I know that having dual monitors is part of the cause because it runs fine when i set it up with only one monitor. What could be my problem?
What kind of video card are we looking at here? I'm wondering if it's some sort of driver/hardware limitation. I know most when you use duel monitors will simply black out the secondary one... Are you using special software or something?
the only drivers i have for it are the ones that came on the cd.
ya the video card does not support dirrect 3d. you may need a new one
I know the card supports direct 3d, as i said before, i tested it using only one monitor, and it works fine.
