Is speedfan right?
I just installed speedfan and it says my processor cores are running at 12*C and 18*C. Is it correct? If so, that is pretty darn good.
yeah i think speedfan can have a mind of its own sometimes! but then again everything i do is very intense so what ya gunna do? :)
I have PC Wizard on my vista x64 :confused: the only thing that dont work right with pc wizard is the bechmark, everything else works fine
I wouldnt believe that unless either your room is very cold, or you have some kind of extreme cooling solution.
I have whats in the sig, the Thermalright Ultra Extreme 120 with a SilenX 120mm x 38mm Fan(90CFM) and some AS5. I didn't follow the directions for AS5;) I noticed when I put it in the middle that only the middle radius of the chip got the paste. So, I put little dots about 2mm away from the edge of the chip and worked my way to the center. My room stays at 72*F....
PC Wizard says that Core1 is 18*C and Core2 is 11*C, and it says the processor is 180*C:rolleyes: I don't know what to believe. It says the mainboard is 255*C, lol.
Yeah use orthos and see, when i run orthos i get about 44*c 100% and 28*c idle.. i didn't know about that cooler when i bought mine :P
I was going to buy a CNPS9700 until someone told me of this, I gotta get to cleaning my desk off, so I can take some pics for you guys.
Heres how I see it:
Temp programs are always wrong.
The Bios I heard is the real way to check the correct temp.
Every single other program tell me my cpu temps 46c and my bios is telling me 71c.
Heres how I see it:
OMG 71*C, Do something about it, you can't even OC on that....
