And with those you can choose whatever you want to be on that object bar? Folders and applications? Because it definitely allows for less clutter. That start button at the top is a theme?
How did you make your icons that big in Xp? :)
Right click the desktop, click properties, then go to appearance, and click effects, or advanced, its one of those. Then there should be a check box with the words.."Use large icons on desktop"
Yeah, you can just drag and drop any folder, or file, or program, and then you can even change the icons. A good place to find dock icons is Deviant Art
The start button is a theme, yes. But you have to have a program called WindowBlinds, and its not free either. But you can always download the trial for 60 days :)
Brilliant thanks so much mate.
they look alot better now.
Vistas icons are quite big and thats why i like them:)
Now maybe you should change your resolution :P Then your icons won't be so small :rolleyes:
I don't know how you can stand 1024x768...
i like 1024x768...anyway i only have a 17" CRT monitor so if i change my resolution would this cause problems?
i think i changed my res before and everything went so small lol.
Should be fine. I have a 15" monitor and it works fine, and I've done it on 17"
I remember that. But now that your icons are big, it shouldn't change anything else except the size of the taskbar :P
Hehe. Your choice :rolleyes:
