King-C New Member Aug 20, 2007 #1 Hi Ive been lo0oking around at Newegg and IC that the 6000 is 3.0ghz and is only 170.00 could it be stable at gaming?
I INTELCRAZY banned Aug 20, 2007 #2 King-C said: Hi Ive been lo0oking around at Newegg and IC that the 6000 is 3.0ghz and is only 170.00 could it be stable at gaming? Click to expand... Yeah, I have heard that you have to up the voltage to 1.4v on those to keep them stable
xxxalpinexxx80 New Member Aug 20, 2007 #4 e6850 is alot better but if you want something good and low price, this is the way to go, you are gonna need to dcide on a whole new board
xxxalpinexxx80 New Member Aug 20, 2007 #5 it will bestable if you just hop it in stock, and if you have to change the voltage which i doubt ur gonna have to, its easy, i would prob say this is a really fast processor for the price point
maroon1 New Member Aug 20, 2007 #6 Don't be fooled by GHz E6550 performs on par with 6000+ even though it has lower GHz And I would get C2D E6550 over 6000+ because it run cooler, consume less power and overclocks way much better
R RoBBy New Member Aug 20, 2007 #7 All Core 2 are more powerful than the AMD, but it get more hot too i think, that's why u always need a good cooling.
jimmymac VIP Member Aug 20, 2007 #8 RoBBy said: All Core 2 are more powerful than the AMD, but it get more hot too i think, that's why u always need a good cooling. Click to expand... not all, the x2 6000 can put itself on a par with the 6400 and in some benchmarks the 6600, so its better than a fair few of the lower end Core 2's I expect the upcoming x2 6400 will performing more regularly near the 6600
