it's a 775... i don't think there's anything to damage
the pins have already been lapped off for you
1. place 775 cpu pin side on bottom on hand.
2. push cpu down toward the hand like you should when you install a cpu and lock it with the cover.
3. if you feel pain and or blood, this is normal.
4. proceed with sand paper rubbing it in a circular motion.
5. after 20 minutes or rubbing......
I still say use that piece of foam it ships with.. it'll protect the underside of the cpu while your shaping it with sand paper![]()
I wouldn't do it at all, you'll void the warranty
I agree the foam If you still have it. If not anything soft I suppose, Since it's LGA, land grid array, It will only have a bumpy surface on the bottom, So you don't need to worry about damaging things if you stick it in, say a couple sheets of paper towel.
Sorry to hear about your crappy day man.
Are you lapping your X6800???
