b3rt_d4ni3l
I thought it was 128MB? 256MB recommended?
See if your brother can get memtest86 on an CD for you. Scan your memory, if it comes up bad then you'll need another stick.
I don't think he can do that because he couldn't even install XP.
If the problem is like what Cromewell had said, what he should do is take out one stick of RAM and try installing XP if it still fails try putting in the other stick and try installing again.
