Makdaddymac
i have a basic pc....that needs 911
it was moved to replace the comp desk.and when put back it wont work...like all it does is turn on. the fans spin,and i think the hd is working cause i hear it and the hd light blinks...but the monitor/keyboard dont do nothing. as if they werent hooked up(yes i checked the connections a hundred times)..i hooke up another dekstop to the same cables and everything ran fine,monitor clicked on and showed the bios booting etc.......
what should i check??? im thinki its the motherboard....but it could be the HD.
how should i go about this...
