2900 pro by far dont listen to them they're wrong
Get some test with there newest drivers!
2900 pro easily, you cant just say 8800. 2900 pro is a underclocked 2900xt, you can just oc it to xt speeds easily...
and the 2900 xt even beats the 8800 gtx in some benchies
id say if youre looking for dx10 games id go with the 2900 pro easily
the only reason it loses out whern AA is on, is because it uses a shader based AA, which can be applied to HDR, thats awsome beyond belief.
the 8800's can force AA onto hdr scenes, but its baaad. lots of glitches with bioshock etc with the forced AA
[-0MEGA-];788346 said:You guys really need to do some research and not just guess. The 2900PRO only does better in 3DMark, check out some real game benchmarks.
http://pclab.pl/art28806-3.html
I showed you at least 5 different game benchmarks. All of those use the UT3 engine, so they are obviously going to have the same kinds of results. The unreal engine has always favored ATI cards anyways, so it's no surprise the 2900XT does better, but remember, this is about the 2900PRO!!dude its because AA is on, and thr 2900 uses a shader based AA, which is why it takes a huge hit. The shader baed AA will be used in newgen games.
look at the medal of honour airborne becnhmarks for both on the unreal 3 engine and the 2900xt is smookkinn
http://www.legionhardware.com/document.php?id=680&p=4
hmmm ....
and bioshock
http://www.legionhardware.com/document.php?id=680&p=1
REMEMBER BOTH GAMES ARE RENDERED ON THE UNREAL 3 ENGINE!!
