Looking for a desktop!
adam98150
Anyone got a UK based link to any sites or shops for a desktop?
Well the maximum i want to spend is around £300. Dont want to spend much more because its a 2nd pc but could do if i have to.
The specs?
-Dual core or Duo
-1gb Ram
-Decent graphics card
Thats about it, not too fussed about harddrive.
The specs?
-Dual core or Duo
-1gb Ram
build one yourself I'm not from the uk but there are other people like kornowski that are in the uk and could tell u where to get parts
Best to build to a nice custom machine and get more for your money, but if you don't feel comfortable doing so then you can get a retail caomputer like a hp or compaq.
I just don't think you will get much at all for £300, and it wouldn't be dual core. Even if you were to build yourself you might be able to fit a low end dual core in the budget
It doesn't come with a graphics card:
This one looks good,
http://www.ebuyer.com/product/128219
But then again it doesn't come with a graphics card, I don't think you'll be able to find one for that price that comes with a good one, sorry.
The Gateway model.
'Intel® Graphics Media Accelerator 950 Up to 224MB Shared Video Memory'
"Experience smoother video, vibrant photos and fast gaming with premium Intel® graphics featuring up to 224MB shared video memory."
Isn't that a graphics card? If not can i put some form of Nvidia in the Gateway? Maybe a 7 series model?
The Gateway model.
on board is crap and u can put a nvidia in that computer
Yeah its onboard, but you won't be able to play games with it. Though you can upgrade it later down the road.
You can't remove the onboard, when you add a nvidia card in the PCIe 16 slot it should "disable" the onboard, if not you can do it in bios which is easy
Cheers!
What sort of Nvidia would you recommend which is compatible with this machine? Maybe a Geforce Go 7600?
Yeah, it'd be fine, but if you were to stick something like an 8800 in there, you'd probably need to upgrade the power supply.
Yeah, that 7600 would be cool! :)
