Watzzupp
Hey,
Been having troubles with my new set-up since the word go, my current problem is one I haven't come across before so I thought I'd ask for some more experienced help
Ok, so here goes:
When starting my comp, it boots into windows fine.
After a while (sometimes 5 minutes, sometimes 3 hours) the comp freezes and the HDD light stays on; well it "kinda" freezes, for instance i was about to watch a dvd in media centre when it froze. The menu kept playing (from what i assume was still in the RAM) but everything else is frozen.
Just the HDD light stays on.
I'm thinking it's my PSU again; I have it under pretty heavy load when you think about it only being 430w.
I have also had RAM problems which i "think" are unrelated but i might post about that on another thread (only running one stick atm, one appears to be damaged physically -from what the tests tell me anyway - Possibly caused by PSU power fluctuations????)
Comp specs are in my sig
Thanks for you help in advanced,
Derryn
EDIT: I forgot to mention my HDD's are both WD 160GB, the one running vista is SATA, the other has apps and media and is IDE.
EDIT2: I should also mention that the chipset gets quite hot quickly and after these freezes, the bios or windows doesnt show my Pioneer 212 SATA dvd burner (when you turn it off and on again it comes back) - another PSU prob???
Ok, so here goes:
Derryn
