F***... Cpu Fan Will Not Spin...
maxudaskin
CPU Cooling, sucks...
What should I do to get it to work, or what Mobo & CPU should I get from http://www.tigerdirect.ca to modernize my computer. I do nt want to spend more than 300 CAD for both combined, but I am willing to upgrade the CPU in the future... I want a good mobo.
wafflez
did you try opening your computer to see if it's spinning? chances are, speedfan isn't reading an rpm because your fan doesn't support that feature...
For instance, take a look at the rpm mine reads >_>:
ThatGuy16
you idle in the 40's? :p
Well on speedfan for me it don't show any of fans as spinning... eventhough 2 are connected to the mobo
Kornowski
Fair enough, just Speedfan tells me I'm getting like 22c idle, BIOS says 19c idle and TAT and Coretemp say 34c... So I tend to go with Core Temp just to be safe ;)
StrangleHold
Moderator
Try PC Wizard or Sandra Lite, looks like speed Fan isnt picking up anything right on your computer. Look a the P/S readings at the bottom!
