Help
Serenade_Me
<b>VIP Member</b>
http://i82.photobucket.com/albums/j271/JenniiBabe16/errormessage.jpg
http://i82.photobucket.com/albums/j271/JenniiBabe16/error.jpg
http://i82.photobucket.com/albums/j271/JenniiBabe16/error2.jpg
What's wrong with my computer? I've ran a bunch of virus scans, but I still get tons of popups, error messages, and my computer runs slower than my '94 IBM. The worst part is there's no way for me to get my 700+ pictures off because my comp refuses to burn anything onto my flash drives or cds. :(
any suggestions?
You have some kind of adware or trojan. I have seen this a few times.
You need to run a program called Hijackthis and post the results here for someone to take a look at.
It is a free program that lists all the process's running on your system. Someone here with knowledge can help you out if you post it.
You can download it from the following link, It is freeware, so don't worry about the cost of it.
http://www.trendsecure.com/portal/en-US/tools/security_tools/hijackthis
The last two ones, with the message, "Your computer may be infected..." Ignore them. Sites have them on to try and make you think that you are, they're often virus' themselves. :)
Serenade_Me, What were you doing when you saw that error pop up? What program were you using, or trying to use?
The first error may be related to RAM hardware failure, i have experienced this myself, and the one program to keep crashing prior to my OS failing was internetexplorer, but from what you said your computer is most likly infected to some degree.
thanks for all the responses :)
this thread alone took me over an hour, 3 reboots, and a virus scan to get through. Hahaha
Whenever I get that message it's usually when I x out of ie. And no matter how many times I click okay it doesn't go away .. unless I go into processes and shut it off, but that isnt helping anything.
and I'm gonna run the HijackThis thingy now =]
One way around IE crashing? Don't use it. Use firefox instead!
It is much more stable than IE and has a ton more options to it. Tabbed browsing, plugins and much more.
http://www.mozilla.com/en-US/firefox/
I tend to disagree, i gravly disliked IE6 and was using firefox, when IE7 came out i didn't switch straight away, but i slowly went back to it.
I know a lot of people say firefox is more secure, well it probably is, but if you surf with care and know what you are doing its unlikly your going to come a cropper. but anyway its personal preference at the end of the day
I've heard about firefox being really good, but I never got around to downloading it.
Once I clear this up, I'll definitely give it a try though. It can't hurt. haha
I see your using Norton. If your happy with norton then stick with it but from personal experience and of others, its one of the worst anitvirus that you can buy.
I would highly recommend Kaspersky. excellent piece of software with out the annoyying crap norton gives you.
Firefox is good, but I don't really find any advantages to using it over IE now, Yeah, there were some when IE6 was around, but now there's IE7 I never touch FF. I keep it installed just incase though :P
If you are looking for a new Anti-Virus, then I recomend AVG, although I've heard that Avast is also good. But let's not talk about it, eh, we'll cause some arguments ;)
Have you tried going back to a restore point before you noticed it all happen?
You need to copy and paste the log file from hijackthis here, posting a picture is not very clear and makes it hard to read.
Ditto. IE might be bad, but FF is just as bad with some memory leaks and stuff..
k. here it is =]
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\PROGRA~1\MOVIEL~1\MOVIEL~1\MOVIEL~2.EXE
C:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
C:\Program Files\Norton Save and Restore\Agent\VProSvc.exe
C:\Program Files\Movielink\MovielinkManager\Movielink User.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\Program Files\Norton Save and Restore\Agent\VProTray.exe
C:\Documents and Settings\PETER\Application Data\S?mantec\l?gonui.exe
C:\Program Files\QdrPack\QdrPack9.exe
C:\Program Files\Canon\CAL\CALMAIN.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\PROGRA~1\McAfee.com\PERSON~1\MpfAgent.exe
C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLLoginProxy.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://securityresponse.symantec.com/avcenter/fix_homepage/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = \blank.htm
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {0B82F303-5AEA-402B-9D73-F0BC9A50B3B8} - C:\Program Files\Windows NT\hokemoq83122.dll (file missing)
O2 - BHO: (no name) - {1B36A556-2E25-4648-9E48-4CE3C41FB758} - \
O2 - BHO: (no name) - {1E8A6170-7264-4D0F-BEAE-D42A53123C75} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.5\NppBho.dll
O2 - BHO: (no name) - {277FC287-96DF-42F0-AEEB-BAC3269210CE} - \
O2 - BHO: (no name) - {37111013-8F27-4CDD-A4B5-1E748C15292A} - \
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: (no name) - {5B5A8CF9-6F4D-46E5-9676-756E5EE557E4} - \
O2 - BHO: UberButton Class - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: (no name) - {5D99A2DA-A0E8-46D2-A028-79EB4A7B458A} - \
O2 - BHO: YahooTaggedBM Class - {65D886A2-7CA7-479B-BB95-14D1EFB7946A} - C:\Program Files\Yahoo!\Common\YIeTagBm.dll
O2 - BHO: (no name) - {6DE1D1DB-74DF-4227-9737-6B1B3084732C} - \
O2 - BHO: (no name) - {7ADF5CFC-5E4F-4059-992B-65B8F2E14D94} - \
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: (no name) - {811802C1-6DD4-49EA-B147-C1C1C4E6BAFB} - \
O2 - BHO: (no name) - {834E1C29-B395-4836-A21E-B9DB0B0E23CF} - \
O2 - BHO: (no name) - {869A71B3-BD37-4A3A-AE83-21DE65197EF3} - \
O2 - BHO: (no name) - {86EDDC87-B6F7-468A-909F-EA3963EBD280} - \
O2 - BHO: (no name) - {89AD4D75-2429-462e-BD4E-443F233F6033} - C:\WINDOWS\system32\nqaesane.dll (file missing)
O2 - BHO: BndShell3 BHO Class - {8ABA9A9C-8791-4d61-8D5B-BCC9448EA573} - C:\Program Files\ISM\BndDrive7.dll (file missing)
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: (no name) - {966E38A1-6A6D-4E12-B7D0-F6DD50D52C14} - \
O2 - BHO: (no name) - {B0D8BA0B-A790-4CB1-BAB2-42593657AB22} - \
O2 - BHO: (no name) - {B31636E9-ECB1-49CF-A470-91CDD1405CF4} - \
O2 - BHO: (no name) - {BEFE9569-CA76-41DC-9F4D-42F4D66316E4} - C:\Program Files\Windows NT\hokemoq4444.dll (file missing)
O2 - BHO: (no name) - {C4B44D3B-91F1-44BE-9402-5AE4076BE912} - \
O2 - BHO: (no name) - {c782ccb3-8b65-420b-a6ef-6b5ef27f9a34} - C:\WINDOWS\system32\fbkfsio.dll (file missing)
O2 - BHO: (no name) - {D72F5856-6C85-45EB-A794-A3CB53ED7A51} - \
O2 - BHO: (no name) - {DE411483-A64F-A3E8-17A5-803A954B15E5} - C:\WINDOWS\system32\sucbo.dll (file missing)
O2 - BHO: (no name) - {DF6A1228-AE58-48B9-AA2E-254CDA2D98C1} - \
O2 - BHO: (no name) - {E35D9467-42AB-4F22-82D3-5C1CF36017BB} - \
O2 - BHO: (no name) - {F9AA51A6-8B42-47D0-9DCA-8F0ECC1CBE16} - \
O3 - Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - (no file)
O3 - Toolbar: Show Norton Toolbar - {90222687-F593-4738-B738-FBEE9C7B26DF} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.5\UIBHO.dll
O4 - HKLM\..\Run: [RoxioEngineUtility] "C:\Program Files\Common Files\Roxio Shared\System\EngUtil.exe"
O4 - HKLM\..\Run: [RoxioDragToDisc] "C:\Program Files\Roxio\Easy CD Creator 6\DragToDisc\DrgToDsc.exe"
O4 - HKLM\..\Run: [RoxioAudioCentral] "C:\Program Files\Roxio\Easy CD Creator 6\AudioCentral\RxMon.exe"
O4 - HKLM\..\Run: [Optimum Online] C:\Program Files\Optimum Online\Netsurf.exe -tray
O4 - HKLM\..\Run: [AcctMgr] C:\Program Files\Norton Password Manager\AcctMgr.exe /startup
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [freexstyle] lockbr.exe
O4 - HKLM\..\Run: [LVCOMSX] C:\WINDOWS\system32\LVCOMSX.EXE
O4 - HKLM\..\Run: [LoadMSvcmm] "C:\Program Files\Movielink\MovielinkManager\Movielink User.exe"
O4 - HKLM\..\Run: [sys011126495901-] C:\WINDOWS\sys011126495901-.exe
O4 - HKLM\..\Run: [win32101-112649590] C:\WINDOWS\win32101-112649590.exe
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1130622577\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [NapsterShell] C:\Program Files\Napster\napster.exe /systray
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [osCheck] "C:\Program Files\Norton Internet Security\osCheck.exe"
O4 - HKLM\..\Run: [Norton Save and Restore 2.0] "C:\Program Files\Norton Save and Restore\Agent\VProTray.exe"
O4 - HKLM\..\Run: [bcdb09cc] rundll32.exe "C:\WINDOWS\system32\ryhxjubv.dll",b
O4 - HKLM\..\RunServices: [freexstyle] lockbr.exe
O4 - HKCU\..\Run: [freexstyle] lockbr.exe
O4 - HKCU\..\Run: [Aim6] "C:\Program Files\AIM6\aim6.exe" /d locale=en-US ee://aol/imApp
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [AOL Fast Start] "C:\Program Files\America Online 9.0\AOL.EXE" -b
O4 - HKCU\..\Run: [Lsfd] "C:\Documents and Settings\PETER\Application Data\S?mantec\l?gonui.exe"
O4 - HKCU\..\Run: [Rsee] "C:\WINDOWS\ASKS~1\javaw.exe" -vt ndrv
O4 - HKCU\..\Run: [QdrPack9] "C:\Program Files\QdrPack\QdrPack9.exe"
O4 - HKCU\..\Run: [Tracks Eraser Pro] C:\Program Files\Acesoft\Tracks Eraser Pro\te.exe min
O4 - HKUS\S-1-5-18\..\Run: [ALUAlert] C:\Program Files\Symantec\LiveUpdate\ALUNotify.exe (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [POSTRBT] C:\Program Files\Norton Internet Security\Norton AntiVirus\Navw32.exe /REMEDIATE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [ALUAlert] C:\Program Files\Symantec\LiveUpdate\ALUNotify.exe (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [POSTRBT] C:\Program Files\Norton Internet Security\Norton AntiVirus\Navw32.exe /REMEDIATE (User 'Default user')
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O8 - Extra context menu item: &AIM Search - res://C:\Program Files\AIM Toolbar\AIMBar.dll/aimsearch.htm
O8 - Extra context menu item: &Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
O8 - Extra context menu item: Add to Windows &Live Favorites - http://favorites.live.com/quickadd.aspx
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Program Files\Yahoo!\Common/ycmap.htm
O8 - Extra context menu item: Yahoo! &SMS - file:///C:\Program Files\Yahoo!\Common/ycsms.htm
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O16 - DPF: {02CF1781-EA91-4FA5-A200-646E8241987C} (VaioInfo.CMClass) - http://esupport.sony.com/EN/mdldetect/VaioInfo.CAB
O16 - DPF: {05D44720-58E3-49E6-BDF6-D00330E511D3} (StagingUI Object) - http://zone.msn.com/binFrameWork/v10/StagingUI.cab34120.cab
O16 - DPF: {11260943-421B-11D0-8EAC-0000C07D88CF} (iPIX ActiveX Control) - http://www.ipix.com/download/ipixx.cab
O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) - http://www.musicnotes.com/download/mnviewer.cab
O16 - DPF: {13149882-F480-4F6B-8C6A-0764F75B99ED} (CrazyTalk4 Control) - http://plug-in.reallusion.com/CrazyTalk4.cab
O16 - DPF: {14B87622-7E19-4EA8-93B3-97215F77A6BC} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab31267.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=36467&clcid=0x409
O16 - DPF: {1754A1BA-A1DF-4F10-B199-AA55AA1A120F} (InstallerBehaviorFactory Class) - https://signup.msn.com/pages/MsnInstC.cab
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O16 - DPF: {3BB54395-5982-4788-8AF4-B5388FFDD0D8} (ZoneBuddy Class) - http://zone.msn.com/BinFrameWork/v10/ZBuddy.cab32846.cab
O16 - DPF: {3FE16C08-D6A7-4133-84FC-D5BFB4F7D886} (WebGameLoader Class) - http://zone.msn.com/bingame/rtlw/default/ReflexiveWebGameLoader.cab
O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} (QDiagAOLCCUpdateObj Class) - http://aolcc.aol.com/computercheckup/qdiagcc.cab
O16 - DPF: {4AD73894-A895-4FC2-B233-299867E08753} - http://apps.deskwizz.com/ax/adwerkz.cab
O16 - DPF: {4FA3D392-9349-4D85-8FB9-18733534CFE3} - http://www.spybouncer.com/downloader/gdownloader.ocx
O16 - DPF: {5736C456-EA94-4AAC-BB08-917ABDD035B3} (ZonePAChat Object) - http://zone.msn.com/binframework/v10/ZPAChat.cab32846.cab
O16 - DPF: {5F8469B4-B055-49DD-83F7-62B522420ECC} (Facebook Photo Uploader Control) - http://upload.facebook.com/controls/FacebookPhotoUploader.cab
O16 - DPF: {613E4C32-2100-4F57-BF9F-CCF26DF9BB4C} (MCCommand Class) - https://aol.movielink.com/commerce/moviemanager/updates/MovielinkManagerInstall.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.c...ls/en/x86/client/wuweb_site.cab?1096644220390
O16 - DPF: {8C279F4E-917E-4CD2-8DF0-D9C73C0CE763} (ZPA_WheelOfFortune Object) - http://zone.msn.com/bingame/zpagames/zpa_wof.cab34501.cab
O16 - DPF: {9522B3FB-7A2B-4646-8AF6-36E7F593073C} - http://a19.g.akamai.net/7/19/7125/1450/ftp.coupons.com/r3302/cpbrkpie.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - http://zone.msn.com/binFramework/v10/ZIntro.cab34246.cab
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} - http://download.av.aol.com/molbin/shared/mcgdmgr/en-us/1,0,0,20/mcgdmgr.cab
O16 - DPF: {BD393C14-72AD-4790-A095-76522973D6B8} (CBreakshotControl Class) - http://messenger.zone.msn.com/binary/Bankshot.cab31267.cab
O16 - DPF: {D719897A-B07A-4C0C-AEA9-9B663A28DFCB} (iTunesDetector Class) - http://ax.phobos.apple.com.edgesuite.net/detection/ITDetector.cab
O16 - DPF: {DA2AA6CF-5C7A-4B71-BC3B-C771BB369937} (StadiumProxy Class) - http://zone.msn.com/binframework/v10/StProxy.cab35645.cab
O16 - DPF: {E991BDE0-9816-4094-853E-6BDB60F0342D} (Get_ActiveX Control) - http://apps.corel.com/nos_dl_manager/plugin/IENetOpPlugin.ocx
O17 - HKLM\System\CCS\Services\Tcpip\..\{0087B670-F2C4-4F58-8A3B-93CCA1D7BE40}: NameServer = 192.168.1.1
O17 - HKLM\System\CS1\Services\Tcpip\..\{0087B670-F2C4-4F58-8A3B-93CCA1D7BE40}: NameServer = 192.168.1.1
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Symantec IS Password Validation (ISPwdSvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\isPwdSvc.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
O23 - Service: Movielink Core Service - Movielink LLC - C:\PROGRA~1\MOVIEL~1\MOVIEL~1\MOVIEL~2.EXE
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee Corporation - C:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
O23 - Service: Norton Save and Restore - Symantec Corporation - C:\Program Files\Norton Save and Restore\Agent\VProSvc.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
O23 - Service: Symantec AppCore Service (SymAppCore) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
O24 - Desktop Component 0: (no name) - C:\Program Files\Internet Explorer\profsyrtylyhd.html
O24 - Desktop Component 1: (no name) - http://www.computerforum.com/avatars/serenade_me.gif?dateline=1157336652
I don't know enough about HJT to help you, so be patient and someone will give you a hand. Be assured someone will help you when they get the time.
The only things I see that are obvious to me are some missing .dll files. But what to fix is beyond me.
