INTELCRAZY
banned
I saw a topic on Xtreme Systems that had the pin mod for 1333Mhz FSB... I want to do this to an E21xx series. I am pretty sure it will work on the E21xx series, it works for the E4xxx series. Question is though, where do I find a conductive ink pen to do this with?
And yes, the CPU is going to be on custom water cooling.. Some of you may ask why.. Well, Intel has 'walled' these lower end series from going over 395-400Mhz FSB, this helps to break this wall when overclocking..
Thanks
Thanks
