Travis30384
1. Was that a pci express card slot?
2. Can laptops with integrated video memory get more by using the pci slots?
----1st post----
Lappy PCI-Express = Express card![]()
You don't have two PCI-E cards in your laptop, they would either be PCMCIA or ExpressCard.ok, if my computer has two pcie slots, a 34 and 54, I will either get a hard drive to go there , or wait until I can get an mxm graphics card. How long do you think this will be, and can i eventually get an updated graphics card for my compaq v6210us?
No it won't, whatever the max you can set now is, is the most you can set it to regardless of RAM.1. I can only set my shared vram to 128mb on startup. Will this increase to 256 when i install another gig of ram? (1gb ram now)
Nope. Video memory is only a small factor when it comes to performance. Honestly, if you set it to 64MB or 256MB (if possible), you won't notice a difference.2. If I set it to 256mb vram/graphics ram, will the performance be AT LEAST as good as a nvidia or ati 128mb card?
Not really sure what you mean, graphics memory and video memory are the same thing.3. What is the difference between graphics and video ram?
I wouldn't use any more then 128MB, however you can probably get away with 64MB. The reason being because you have more available system RAM.oh, oscaryu1, I would NEVER decrease my vram
I know about SSD's. They can be connected via SATA, IDE, or ExpressCard.ok, first, solid state drives can go in pcmia or pcie things like that. They are very expensive. google em.
second, why is my computer able to have up to 288mb vram if you can only set it to 128 when you start up? How do I make it have the full amount "after i install another gig"
I want to help you, but the HP website doesn't go into detail on that. I'm sure some other sites do, so you may want to look around a bit.ok, all of my questions will be answered when this one is.
What exactly does the compaq v6210us have in terms of card slots? I want to know exact numbers, and exact type. Example : 1x pci express, 1xpcmcia![]()
