Jabes
banned
I dunno if anybody has seen this yet but I couldn't find any threads about it so here it is
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103226
Well there's also the L3 cache, but I don't know how effective that is.
As more and more processors begin to include L2 cache into their architectures, Level 3 cache is now the name for the extra cache built into motherboards between the microprocessor and the main memory.
* L1 cache - Then the level 1 cache comes next. It is logically the closest high speed memory to the CPU core / registers. It usually runs at the full speed (meaning the same as the CPU core clockspeed). L1 often comes in size of 8kB, 16kB, 32kB, 64kB or 128kB. But, it is very high speed even though the amount is relatively small.
* L2 cache - The next level of cache is L2, or level 2. Nowadays L2 is larger than L1 and it often comes in 256kB, 512kB and 1,024MB amounts. L2 often runs at 1/4, 1/2 or full speed in relation to the CPU core clockspeed.
* L3 cache - Level 3 cache is something of a luxury item. Often only high end workstations and servers need L3 cache. Currently for consumers only the Pentium 4 Extreme Edition even features L3 cache. L3 has been both "on-die", meaning part of the CPU or "external" meaning mounted near the CPU on the motherboard. It comes in many sizes and speeds.
The L3 cache has been seen in high end Intel processors before, but they were quickly stopped. The latency for L3 cache is pretty high and being the 3rd place the CPU looks for info, it probably isn't that affective.
They are quad cores, and when compared clock for clock with the Core 2 Quad's, they fall a bit short. Although in gaming they are pretty even.Darn, that stinks. So overall how is that compared to a E6850/Q6600?
According to tomshardware, Q6600 is around %13.6 faster than phenom 9600 on average. And thats phenom 9600, not the 9500 on newegg
Didnt you leave the second part off.
The Phenom 9600 is about 13.5% slower than Intel's Q6600 in our benchmarks. On the other hand, its price is also 13.6% lower than that of its direct competitor.
Well if you look at it like that, then later on you will probable be able to get a OEM Phenom cheaper too.Well if you already had a cooler, ClubIT sell's the OEM for around the 9500's price. Not bad![]()
Nope, the Core 2 Quad's are still cooler and quieter.let me know if im mistaken but arnt the amd quad cores alot more cooler and quiter than the intels
