I run two Raptors in a RAID 0 configuration and I am satisfied with the performance.
Isn't that the fastest possible setup?
what if it's not in raid 0
Actually, no. Four in Raid 0 would probably be a little faster.![]()
Whats the difference between setting up 2 wd raptors and having 2 wd raptors but raid 0ing them?
[-0MEGA-];844604 said:If all you care about is speed, then go for the two raptors in RAID 0. However personally I like both, which is why I have 4 320GB hard drives in RAID 0, and I get much faster transfer rates then a single or even dual raptor array would get.
Don't you worry about corruption, losing all 4 drives and data? Or do you back up externally somewhere?
So let me get this clear, If I have 2 wd raptors, I get 10,000 rpm, (higher of the 2, so still 10,000 rpm), 150gb+150gb = 300gb. However if it's in raid 0, it's the same thing just a little faster. Correct?
How do I get raid 0?
Actually, the drives become one, so you get approx. 137 GB of data storage. In order to run a RAID configuration, you must have a motherboard that supports RAID, or a PCI RAID controller. Many motherboards support RAID, so that shouldn't be a problem.
150 gb if he runs raid 1, 300 if he runs raid 0. I think you got confused.
It's always a possibility, but thats why I backup all of my documents, media, saved games, etc to an external 500GB hard drive.Don't you worry about corruption, losing all 4 drives and data? Or do you back up externally somewhere?
RAID 0 combines all the hard drives in the array (given that they are all the same capacity). I'm a bit unclear on what you're asking here, but if you have two 139GB hard drives in RAID 0, you should see one hard drive appear as ~278GB. If you have two 139GB drives in RAID, it's possible you have it in RAID 1 instead of RAID 0.No sir, I'm not confused. Technically, you have two drives for a total of 279 GB. However, since the two drives are combined as one, you only have 139 GB of storage available, not 137 as I incorrectly mentioned in my previous post. If I'm wrong, Omega will correct me. He's running a RAID 0 array as well.
That screenshot was taking after I just installed Windows and some games. I have about 205GB used now, although I'm going to import my media collection to my computer so that will take up most of the space.so why do you have 1.2 terabytes of hdd space if you're only using a fraction of that?
also, do you not partition your drives? what if you need to reinstall windows, when you format wouldn't you lose everything?
