Internet Question
hells3000
So me and my front neighbor want to share internet so ill be doing it wireless.
So I will need a wireless card....
any card will do?
Any card the receives on the same channel as the broadcaster... A/B/G.. N if the router broadcasts on that channel, get a card the receives it.. :) I just got a card from Ebay, as it was 3$ cheaper than Newegg.. Shop around.
any card will do?
any ADSL wireless card will do.
in case u don't know: u will need a wireless modem/router and both u and ur neighbor will have to tune into the same channel. u choose the channel by connecting to the modem/router and setting the channel.
Yes any card will do as long as it matches up with the standard. Say you got a router that broadcast on the G frequency you need a G card. I would suggest you get a USB wireless card if you are not into opening up the case of your PC. I would suggest the "Linksys WUSB54GC Compact Wireless-G USB Adapter". It works with the B and G standards. I have had it for a year for both my desktops and they work without a hitch.
Another good question by [-OMEGA-]. If you are very far, you will either have limited connectivity OR the network will not be detected as it would be out of range of your wireless card.
purchase wireless modem/router and two wireless lan card and configure your connection with wireless network enable ICS on one of ur computer and connect ur computer with internet......
he already has a wireless modem gotten from the IPS
hes gonna be connected wired..
and ill be wireless
Ok another question popped up...
whats does this 10/100 and 10/100/1000 mean?
Those are the speeds that it runs at. 100mbps is pretty much the most you will need. Just get any wifi card, it will work.
so..
does it have to do with net speed?
I.E. 10mbps dsl line it transfer 10mbps?
adsl/dsl same thing?
another question
what are these 8.001a w/e it is standers..?
what are there purpose ?
