Ram For Inspiron 6000
speedaccordinly
hey everyone,
I got some mixed answers regarding ram for my dell inspiron 6000. right now it has the 512mb of ram; 2 sticks. Can i install 1gig of ram or do I need to install 2 sticks of the same ram? i heard it would not recognize if I mix match.??
Thanks,
Vic
SO im assuming my computer will operate efficiently with the mix match. it will not create probs?
It depends on the motherboard. You can put a PC2 4200 or PC2 5300, 200-pin, 1 gigabyte module in and see if it works. If it doesn't work then just remove the old memory module. It shouldn't do any damage to your system.
