Search around the forums. this is probably the most common question.
(edit, sorry if this sounded disrespectful, didnt mean it like that. Just saying that quickly you could find a general build idea then ask specific questions)
Motherboard- ASUS M2N SLI Deluxe
Power Supply- OCZ GameXStream
Precessor- AMD Athlon 64 X2 6400
GPU- EVGA 8800GTS 640MB
Hard Drive- Seagate Barracuda 500GB
RAM- CORSAIR XMS2 2GB (2 of these. making 4 gigs total)
Disk Drive- SAMSUNG CD/DVD RW
Case- Antec Nine Hundred Black Steel ATX Mid Tower
TOTAL: approximately $1125 after rebates
I couldn't let you buy a computer without exposure to AMD
plus i love putting these lists together![]()
so intel is better than amd? or what?
Currently, Intel processors are better than AMD's offerings.
Processor: Q6600 $277.99
HSF: Zalman 9700 $59.99
TP: MX-2 $6.99
Mainboard: Gigabyte P35-DS3L $99.99
Memory: 2GB XMS2 $37.99 after MIR
GPU: eVGA G92 8800GTS + Crysis $339.99 after MIR
PSU: CM Real Power 850W $69.95 after MIR
HD: Seagate 250GB $64.99
OD: Asus $32.99
Case: That's up to you.
Total Cost: $990.87 before S/H, and after MIR's
Feel free to substitute the Radeon HD 3870 for the GTS if you need to save $100.
Boo to Lightscribe![]()
Although, get 2x of this RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144
CL4, and it's 1 cent cheaper than XMS2.
20% faster too![]()
Unless you enjoy a few hours of frustration, do NOT get the antec 900.
Is AMD's Sempron 2600+ (1.6) equivalent to a Intel 1.6? Nope!
They're equivalent to Intel's 2.4GHz...
Obviously. Cache sizes are dramatically different between the two, for example.
In addition to the faster speeds, the Radeon has 320 bit stream processors compared to the 8800's 128. That's a 250% difference. The Radeon is also $105 cheaper. Currently, the only advantage I see with the 8800 is the ability to run SLi and the free Crysis game. I'll look up some benchmarks between the two cards.
Someone correct me if I'm wrong, but the Radeon 3870's specifications appear to be better than the G92 8800 GTS. Performance-wise, does the ATi card beat the nVidia card? For now, I've removed the 8800 from the list and replaced with the 3870.
the 8800 is better.
