X-Fi Extreme Audio
diduknowthat
formerly liuliuboy
Hey guys, I'm was searching for a moderately cheap soundcard and I found this,
http://www.directron.com/sb0792vp.html
X-fi Xtreme Audio for $40 on Directron. I know the Extreme Gamer is a lot better but this is already beyond my expectation, as I was originally planning to get the Audigy SE. What do you guys think of this card, and better this deal?
And also, if you had a choice, would you get the Xtreme Audio, Audigy SE or another card with $40.
And Finally, do you think the Xtreme Gamer/Xtreme Music (the discontinued one) is worth it? If it is absolutely worth it over the Xtreme Audio I will also consider getting that.
edit: oops, spelled Xtreme wrong in title.
the xtremeaudio doesn't have a true x-fi chip in it, whereas the xtremegamer and xtrememusic do.
i have heard of many people modding their xtrememusic to go beyond and achieve more. the xtremegamer however cannot be modded
if you could I would go with a sound card that does have an x-fi in it. after all, a sound card isn't something you upgrade often, like other computer components. it is really up to you, and you also have to take into consideration your speakers and headphones.
I think I'm going to go with the Xtreme Music. I found a used one for $75 shipped on amazon. Too bad they discontinued it :(.
i've got a extreme audio x-fi.....don't really notice a diff betweeen onboard vs. soundcard...it does though...
I just ordered the X-fi XtremeMusic for $80 refurbished (couldn't find a new one for less than $100). It's due to arrive Monday the 28th, can't wait!
Hmm, you must be on quite an expensive site.
I got mine brand new for £28 ($60)
It's a good little card imo, i love the bass feature, that card and my X-Fi gamer headphones is a blast.
The problem is that nobody sells them anymore. Currently it's all about $80 minimum, whether the Xtrememusic or Xtremegamer. Where did you find the Xtrememusic for $60?
