KLM SEA-AMS
Is this possible or does the Radeon require too much voltage?
Are you referring to the voltage on the different AGP slots? If so then yes that does make a difference, and the card will only work with one type of slot - the AGP 4x/8x slot.So that the fact that some MB's can't take a certain voltage or something like that is not an issue here?
Well since I have the AGP 4x/8x slot, there should be no problems. I have a 450W PSU, is that enough for this video card?
Yes, the 2600XT is the best AGP gaming card you can get at the moment.So I will see an increase in framerates? Is this the maximum AGP video card available?
You can't always believe what reviews say, he's probably referring to using the 2600XT in a different AGP slot, such as 2x/4x, which does use a different voltage.So this is not an issue here...
"Make sure when you are using a newer agp card in an older mobo that the agp card voltage is not to much for your mobo. It will trash your mobo before you know it." (from TigerDirect.com product review)
No that is not what it means, they will not fit in the wrong slot.i think it is if u put a PCI x16 on a AGP board it will burn the AGP slot out
