Video editing wouldn't take a really high-end video card, it's more CPU intensive than GPU intensive.
Anyways, if you're not gaming, the most expensive video card I'd recommend is the HD3850
You need more Wattage!!!!! (750w sounds real good)
Get an AMD duoprocessor (more transistors)
with 2G of Ram but leave room for upgrade
OS: XP of course; if Vista I suggest 4G of Ram
Nvidia GeForce 8800 with SLI
any seagate hardrive (prefferably over 250G) ****check rpm*****
system unit: not a good choice pertaining to cooling I suggest an Ultra
and, offcourse Biggest monitor you can afford afterwards
I cant tell you exactly what to get because then it wouldnt be a customization. But I give you soe pointers.
I would reccomend a new psu, if it doesn't have twin 12v rails then the amperage output probably won't be good enough for your setup. Try something around 500+ watts
Also, I forgot tomention ASUS motherboard is great for SLI!!!!!!!!!!!!!
And you do get more bang for your buck if you invest in a nicer video card for video editing. Its not just for extreme gamers.
And I also forgot to mention that you should only post when you know what you're talking about. Honestly!
Any motherboard will be good at SLi...
You invest in a GFX in your PRICE RANGE that is the best bang for the buck![]()
that looks like a nice card.
would that fit in my existing soltek motherboard?
boost the RAM and bada bing?
prolly need a new mobo and cpu with that, eh?
