Ive got Vista Ultimate and loving it!
i havnt had any problems yet with anything ive tried running
it was slow on my old rig but aslong as you have enough ram theres nothing wrong with vista![]()
Cool an't it. I'm running the 32bit one![]()
ah amen to that.From the experience I have had with it, they changed a bunch of stuff from XP for no good reason other than that they could, not because it was better. They renamed and restructured the files system layout for no good reason.
I have to say I don't know why the give bullshit about vista. It's brilliant. Every day I log on. I can check my e-mail,surf the net,play somevideo games,watch films,listen to music,edit pictures,edit films,create films,write esses,do homework,sync stuff to my itouch 16gb. It's GREAT!! Now It had two glitches. One of them being the messed up sidebar which frooze your system. The 2nd one being when I logged on one day it crashed completely and I had to reinstall windows and my life on a different drive. I copied my files etc then I formated the driveNow since thats over the one problem I have is when I logon the wi-fi isn't being picked up I.E I have to restart the pc and logon then it's fine. But usually everyone uses Lan or cable so your safe.
(+ I bring bad luck)
Intel Core Quad Q6600/T7700
4096mb 800Mhz 6400CL5/4gb Ram
2xXFX 8800ULTRA 768mb/8800GTX 512
1000GB/200GB
X1 Blue Ray Disc Drives./Blue way
X1 HD-DVD Drive./ None
Windows Vista Ultimate 32bit OEM/Same
22inch LG Flatron Wide 1680X1050/15.4
Abit IN9 32Max Wi-fi 680i SLI MoBo/????
...and your specs...
... I guess Vista runs decent for you. Unfortunately 90% of PC users, and about the same percent of new machines coming out with Vista OEM do not have that kind of hardware.
Ah come on your on sempron which is like celeron that is soo windows 2000![]()
I was an avid anti-Vista user when it first came out, because XP had major problems when it was first released. There are always going to be bugs and glitches and driver issues, no matter how many "updates" Microsoft releases.
That said, I now am quite a fan of Vista, having run it myself for 6 months problem-free, and having my roommate run it for better than 8 months problem-free. Also, I just installed SP1, which was recently released, and it helped quite a bit. Operates much more smoothly, file transfer speed and such is increased.
The biggest problem out there seems to be not with Vista itself, but with folks trying to run Vista on a below-par system, i.e. not enough RAM, low-end CPU, and you most definitely will benefit from running a 256+mb video card.
Just my .02.....take it for what it's worth.
