eggyhustles
Ok so my hd is failing..so i decided its time to upgrade some parts in my pc..its extremely old (compaq presario 5000t) from 2000
the specs are
Duron-900 CPU
128MB of SDRAM, 64KB L2 cache
Windows xp,
40GB hard drive
Compaq NVidia GeForce2 MX graphics card with 32MB of SDRAM,
i added 256mb of ram and plan to add another 256 to total out to 512 keep in mind that i rarely play games and this pc is only used for internet, music and videos... im gonna put in some pieces i wanted to know if they were compatible to use with this pc
will this video card work on my pc?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3001066&sku=E145-5202
can i use this power supply?
http://www.tigerdirect.com/applicat...details.asp?EdpNo=3588905&sku=VADC-803831-RTS
how is this hd?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=322750&sku=THD-80JB
will my mb support this?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1215759&sku=P511-1066
Also can you guys recommend me a cheap sound card? the intergrated sound on my pc is slowly dying..my budget is only 250...and so far with all these parts i've spent 200.77 dollars(this includes shipping)
Edit- found a soundcard, is it any good?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2177471&sku=D10-2092
Is it stupid that im pouring all this money into such a old pc? if so what do u suggest i do? saving up is not an option since i only get 200 a month and cant go without a pc
the specs are
Duron-900 CPU
Windows xp,
40GB hard drive
how is this hd?
