small budget gaming pc
Cheution
so just wondering if someone can help me build a computer for $500 usd 100 which has to be used at bestbuy(gift card). just want to be able to play WoW on max settings
so $500 can be used anywhere (Newegg.com) and the $100 has to be used for best buy? Or is it $500 total including a $100 best buy card?
sorry for the inconvenience but just payed some bills down to $360 usd :( sorry and thats 360 towards newegg can go over that a little(shipping)
since the challenge is $100 at bestbuy and $360 to 400 elsewhere and no one has given an answer to that, I'll give this a try.
Case+psu 92.99 at bestbuy
http://www.bestbuy.com/site/olspage.jsp?skuId=8545112&type=product&id=1188560188557
same as this on newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129032
CPU-E2200 $84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116063
Mobo-Intel 945GC $50.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128076
Ram-2x1GB $45.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Video Card-8800GS $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150275
HDD-WD 160GB $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
shipping - $8.41
Total 395.36 at newegg, 92.99+tax at bestbuy
there is $30 worth in mail in rebates, so if you use bill me later you can pay 365.36 now and wait for the mail in rebates.
If you are willing to overclock,
the CPU should overclock to 3Ghz on the stock cooler and stock voltage
the Video card has a lot of overclock potential because of the G92 core and once overclocked it is about the same as a 3850.
CPU-E2200 $84.99
Ram-2x1GB $45.99
HDD-WD 160GB $49.99
shipping - $8.41
HDD wise I would recommend the Seagate Barracuda 320GB 7200 RPM 16MB Cache ($80)... only $30 more with double the space and cache
