so $500 can be used anywhere (Newegg.com) and the $100 has to be used for best buy? Or is it $500 total including a $100 best buy card?
wont play WOW on max but i will try.
CPU $47.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103732
MOBO $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135074
Ram $43.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220279
HDD $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
case $22.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147065
PSU $34.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171028
Video card $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161088
thats $364.93.
enjoy
is that a good thing?wow redevil. Thats intense computer building haha gj man
the Video card has a lot of overclock potential because of the G92 core and once overclocked it is about the same as a 3850.
Get the build that simpletron suggested
But try to get this motherboard instead because it is more future proof
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128077
Actually, 8800GS performs slightly better than HD3850 256MB at stock speeds
since the challenge is $100 at bestbuy and $360 to 400 elsewhere and no one has given an answer to that, I'll give this a try.
Case+psu 92.99 at bestbuy
http://www.bestbuy.com/site/olspage.jsp?skuId=8545112&type=product&id=1188560188557
same as this on newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129032
CPU-E2200 $84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116063
Mobo-Intel 945GC $50.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128076
Ram-2x1GB $45.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Video Card-8800GS $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150275
HDD-WD 160GB $49.99
shipping - $8.41
Total 395.36 at newegg, 92.99+tax at bestbuy
there is $30 worth in mail in rebates, so if you use bill me later you can pay 365.36 now and wait for the mail in rebates.
If you are willing to overclock,
the CPU should overclock to 3Ghz on the stock cooler and stock voltage
shipping - $8.41
