ExtremeAlien
Well I have been wondering since I havee put in my fans if its the best possible airflow or should I switch the intake and exhaust? This is my current setup, note this is not the case i have but it is EXACTLY identical. (I have an Ultra Aluminus full-tower.)
The reason I have intake in back is because I have a window there so its cooler air going into the system instead of front and I have a separate fan blowing from that window. Would I get better temperatures the other way or would it just be a waste of time?
Current temps: All in celcius
cpu = 35 degrees Usually always in load (old processor)
mainboard = 29 degrees
ACPI thermal zone = 40 degrees (What is this?)
gpu = 50 degrees (idles at 47 usually)
Hard Drives = 30 degrees
Fans are Scythes, Ultra Kaze's 3000rpm
