well i tried again. restarted and it seems that the theme works and stays but my start menu has still not converted to the new look. any suggestions?
ok i found the problem. my start menu was set to "classic start menu". i changed it to start menu and now i have the vista theme start menu. but....
i am now having trouble with the left side of the start menu overlapping the words on the right side of the menu.
any fixes for this? i looked back and saw someone else have this problem and tried the solution but it didnt work.
thanks in advance guys.
I would suggest using Vistart. It looks and acts exactly like the real Vista start menu. Just give it a try.
~Jordan
actually it doesnt work for me.
anyone with suggestions on fixing the overlapping start menu?
how come wen i try to start vistart i get some registry error?
Have you tried not using Vista Art and using the theme I've posted on the 1st page?
Can you change the colors like you can on the REAL vista?
(what im trying to say is, can you change the bars and whatnot to red, orange ect...?)
Seriously the easiest way to get Vista theme is VTP. (vista transformation pack) It's free!
Yeah, but the problem lies when you come to un-install it, it can't be completely removed and leaves traces of itself even when un-installed...
