Does anybody know the dba(noise lvl) for the 120 fans?
I hate noisy computers and the Antec fans are doing just that. Does anybody know of any 120mm fans that is near silent?
thanks
Yeah, on medium and high settings they are noisy. That's just the way tri-speed fans are. To fix that, check the switch setting, make sure it's on low.
I run all fans on the high settings since the 120s along with the top 200mm fan run straight off of the supply without any controller even used.
The Antec Tri-cool fans are anything but quiet except in the "low" speed mode. They quickly become audible in medium/high mode
You're still up?! No parental supervision I guess. It's ready well past your bed time there. Let me know when you mature a little so you finally get off the "ignorant" list. Otherwise...
As for replacing them with Nexus or any other fan, there's really no difference aside from RPM and CFM. I believe the low setting on tri-cools is 1200RPM. Nexus "real silent" fans, of which I currently have two in my case, have a max RPM of 1000 at 12V. When undervolted they can get down to ~600RPM like I have mine. There's no way to get the same airflow with a Nexus fan that you can with a tri-cool and they really don't belong in any expensive computer that makes a lot of heat.
