Hello! I'm about to build my first computer since 1998, and would like some input.
Is everything compatible? Is there anything else I can do? Any suggestions will be helpful. Thanks guys.
Ultra X3 ULT40064 1000-Watt Power Supply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2700093&Sku=ULT40064
ASUS Black 16X DVD-ROM 48X CD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135143
ASUS Striker Extreme LGA 775 NVIDIA nForce 680i SLI ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131074
2x EVGA 768-P2-N831-AR GeForce 8800GTX
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130072
Intel Core 2 Duo E6850 Conroe 3.0GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028
Western Digital Raptor X WD1500AHFD 150GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136011
XCLIO Windtunnel
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103011
ZALMAN 9500A 92mm 2 Ball CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
OCZ ReaperX Dual Channel 4096MB PC6400 DDR2 800MHz Memory
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3495740
Thanks again.
XCLIO Windtunnel
Thanks again.
