XFX Geforce 8800GTX
wellhellothere
Just before i empty my pockets...
Can you tell me if this card:
http://www.ebuyer.com/product/142610
Would fit in this motherboard:
Asus ABN SLI-PREMIUM (dont think its on the market anymore - try a google search)
Im 99.9% sure, as my board has a PCIe slot and i've run several cards with it just none this good. Any other info is greatly appreciated. PSU: 500w, CPU: althon64 4600+ x2.
Nice one for the help guys. Yeah, i've got a huge case so i should be fine. Do you know if this is a particularly power hungry card? And if its good? (i've only heard posotive things about it)
Here's the minimum power requirements:
Minimum of a 450 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 30 Amp Amps.)
That 500W PSU is cutting it close with the GTX...get the 8800GT, it's almost a good, and less power hungry/big.
Any ideas how the 8800gt handles games? for example cod4, oblivion, crysis etc etc. I did consider this card (it seems a bit more realistic for my setup - i dont have a super computer!)
Thanks!
I run Crysis at 1024x768 with 8xAA and everything on Medium and it's flawless. I can't be bothered with constant fiddling but it's probably possible to run it with better graphical settings also with what I have it looks great to me. COD4 is not a problem with everything on high.
Shite! So the PSU couldnt really run the card? Can you reccommend a decent PSU that would stand a chance?
this is the one i'm going to be getting:
http://www.newegg.com/product/product.aspx?item=N82E16817182017
i know that you can run a 8800 with that.
this is from ceewi1 of this forum:
nVidia Multiple Card
Card...................................Wattage ...............+12V Amperage
7600GS SLI............................400W .........................20A
7600GT SLI............................400W .........................24A
7800GT SLI............................450W .........................26A
7900GS SLI............................500W .........................28A
7950GT SLI............................500W .........................28A
7800GTX SLI..........................500W .........................34A
8500GT SLI............................400W .........................22A
8600GT SLI............................400W .........................22A
8600GTS SLI..........................450W .........................24A
8800GTS SLI..........................650W .........................52A
8800GT SLI............................600W .........................48A
8800GTX SLI..........................700W .........................56A
8800Ultra SLI.........................750W .........................60A
9600GT SLI............................450W .........................28A
nVidia Single Card
6200LE..................................250W .........................18A
7100GS.................................250W .........................18A
7300GS.................................300W .........................18A
7300LE..................................350W .........................18A
7300GT.................................350W .........................18A
7600GS.................................350W .........................18A
7600GT.................................350W .........................18A
7800GS.................................350W .........................20A
7800GT.................................350W .........................20A
7900GS.................................350W .........................20A
7950GT.................................350W .........................22A
7800GTX...............................400W .........................26A
8400GS.................................300W .........................20A
8500GT.................................300W .........................18A
8600GT.................................300W .........................20A
8600GTS...............................350W .........................18A
8800GTS...............................400W .........................28A
8800GS.................................450W .........................30A
8800GT.................................400W .........................26A
8800GTX...............................450W .........................30A
8800Ultra..............................500W .........................34A
9600GT.................................400W .........................26A
9800GX2...............................580W .........................40A
