Sweet! So this is what I have so far.
Motherboard - EVGA nForce 750i SLI FTW Motherboard - NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LAN, S/PDIF, USB 2.0, Firewire, Serial ATA, RAID (4 lbs)
CPU - CP2-DUO-Q9300 :: Intel Core 2 Quad Q9300 Processor EU80580PJ0606M - 2.50GHz, 6MB Cache, 1333MHz FSB, Yorkfield, Quad Core, OEM, Socket 775, Processor (0.1 lbs)
CPU Cooler - C283-1160 :: Cooler Master RL-EUL-GBU1-GP Aquagate S1 Liquid Cooling System - Socket 775, 754, 939, 940, AM2 (4.6 lbs)
Video Card - EVGA GeForce 8800 GT Video Card - 1GB DDR3, PCI Express 2.0, SLI Ready, (Dual Link) Dual DVI, HDTV
Memory - Corsair XMS2 DHX 4096MB Dual Channel PC6400 DDR2 800MHz Memory (2 x 2048MB)
Power Supply - O261-2005 :: OCZ / GameXStream / 700-Watt / ATX / 120mm Fan / SATA Ready / SLI Ready / EPS / Active PFC / Power Supply (5.6 lbs)
DVD Burner - L12-1132 :: Lite-On LH-20A1S SuperAllwrite SATA DVD Burner - 20x DVD±R Burn, 16x DVD±R Read, 8x DVD+RW, 6x DVD-RW, 8x DVD±R DL, 12x DVD-RAM, 48x32x CD-R/RW (2.2 lbs)
Monitor - H25-GM757 :: HP w2207h 22" Widescreen Flat Panel Monitor - 5ms, 1000:1 Static, 1680x1050 (WSXGA+), DVI, VGA, Black (24.7 lbs)
Keyboard - L23-7290 :: Logitech Wave Keyboard - Multimedia, USB, PC/MAC, Black (4 lbs)
Mouse - L23-7800 :: Logitech RX300 USB Optical Mouse - OEM, USB, Black, Optical 800 dpi, 3-Button, Tilt Wheel, Vista Ready (0.35 lbs)
Case - ULT40069 :: Ultra m998 ULT40069 Mid-Tower ATX Case - Aluminum. Clear Side, Front USB 2.0, FireWire, eSATA and Audio Ports (30 lbs)
OR Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Hard Drives - Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM 16MB Cache SATA 1.5Gb/s Hard Drive - OEM
What do I need to know to make these two hard drives and 2 video cards run smoothly? Anything?
Thanks again guys! Anything that you think you need to mention would help!
