Best CPU for Adobe design programs?
Tis allright :)
If you cannot find the installation file (CD, DVD, ect), then you can use Norton Ghost to transfer the whole OS and files to another HDD.
i heard that there is a legit website that gives you product keys for programs and then you download from Adobe and use the free key you got. You guys know anything about that?
Also i had a question about those gaming headsets that have a connected microphone. Can you use it as like a voice recorder for adding voice and sound effects to your movies in Flash and other programs? And does anybody know if Dell's basic speakers are any good?
If you want some good speakers and sound card i can recommend you one....
I just bought this CPU, can you guys tell me if this system is legit for the price?
Dell Refurbished SE198WFP 19-inch Widescreen Silver Flat Panel LCD Monitor
$165.00
1
$165.00
XPS 720 Tower: Intel Core 2 Q6600 Quad-Core (8MB L2 cache,2.4GHz,1066FSB) Black Chassis Genuine Windows Vista Home Premium
1
$1,019.00
Certified Refurbished
No Speakers
No Modem
Dell Optical USB 2-button Mouse
No Floppy Drive
Power DVD Software
No Raid
Service Software
Power DVD Software
Operating System Label
Shipping Material
Software
512MB Nvidia GeForce 8800 GT
500 GB SATA Hard Drive (7200 RPM)
Processor Label
Software CD
Dell Solution Center Software
No Optical Device
Audio Jacks For X-Fi Sound Card
3 GB DDR2 SDRAM 800MHz (4 DIMMs)
Lord Of The Rings Online
Sound Blaster X-Fi XtremeGamer (D) Sound Card
Microsoft Works 9.0
16X DVD +/- RW w/dbl layer write capability
Reference Guide
USB Keyboard
ISP Search Assist
Operating System DVD
Documentation
Image Restore Software
Resource CD
Roxio Creator DE
XPS 720 STD: 1 Yr Ltd Warranty and On-site Service
$0.00
1
$0.00
Dell A225 Two-piece Stereo Speaker System
$20.99
1
$20.99
WNDA3100 RangeMax Dual Band Wireless-N USB 2.0 Adapter
$79.99
1
$79.99
Save 10% on select Networking!
- $8.00
Subtotal:
$1,276.98
Shipping and Handling:
$34.98
Shipping Discount:
-$29.99
Sales Tax:
$99.35
Total:
$1,381.32
I really want to get a PC because there much less money but has anyone here used adobe on both PC and MAC? Ive only ued Adobe on MAC, I just wonder how much different its is on PC? On Mac you just drag pics off the internet and start editing. Its it much different and harder on PC?
Abode codes their apps pretty much the same on both the Windows and OS X sides of things. The only differences will most likely be keyboard short cuts and that is it.
Don't worry about getting a good video card because gaming cards only really boost performance in gaming period.
Whether you get a mac or a PC is up to your preferences really. They will probably perform very similar to each other, and each has their advantages over the other.
My screen came with a special DVI cord and says that if i have some special graphics card i use DVI cord to enhance image. How do i know if my video card is DVI capatiable?
You look for the big white/gray port on the back of a graphics card. The 8800gt is compatible.
