ThatGuy16
And where did you get the green lights / switches from?
All from Radio Shack, rocker switches, and i decided on those LED's because they come with the housing, 12v resistor, and are already wired.
whyd u swap ur apollo?
Not that ur new case doesnt look sick but ur apollo was insane.
I also changed the stock fan on my heatsink to a blue LED.
Turn the fan around so its blowing air over the heatsink, i think youll be pleased with the difference![]()
i just notised that he will deffently see a temp increase if he flips that CPU fan the other way so the air is blowing onto his heatsink
It's already blowing down guys!
I idle at about 39-43. Not sure on a heavy load though.
It's blowing up.
Hey voyager, did you take out the fan to see where the air is flowing? Cause if you just put your finger on top of it to see if you felt air, you can still feel an air current on the side of the fan where it is puuling the air from.
I think that ^ was just more confusing!![]()
If I am correct even the stock intel cooler blows into the heatsink instead of sucking air out?
