Post A Pic Of Your Pc Here :)
lol
How does it perform??? How does boot camp etc go....
Easy to set up / install?
BOOT CAMP? Easy kinda.
Tutorial for future reference (what I did):
Go to bootcamp assistant and make your partition
(some say after this go to disk utility And format it as MS DOS FAT32 I didnt)
Put in your XP/Vista Disc and the Mac Will restart it will boot into the windows setup and choose your language and install. When you choose your partition make sure you choose the one marked bootcamp (You will know by the amount of GB you gave the partition) Otherwise you will need to use a recovery disc and phone APPLE. Choose your bootcamp partition and if it all goes well you will get an error : Wrong format. Just reformat it as NTFS and move on. When you restart make sure you don't press anything otherwise you will boot into the DVD instead of Hard disk. When it finishes installing go to your books entitled : Everything else and pop in the Recovery disc 1. (First you need to eject the Vista/XP disc by going into my computer following clicking on Drive and eject. You pop in the Disc and it will copy the drivers afterwards restart and it will boot into xp/vista once more.
Finished. (I then went into bootcamp utility (icon on taskbar) And choose when restart Mac OS 10 Tiger/Leopard (I choose leopard but shouldn't case your using tiger) I made sure that it was always going to be set for Mac OS and if you ever need to boot into windows you just have to press the Option key when you first hear the chime. (Option key is ALT took me 2 hrs to find it)
Danny nice mate!!!
How much did that set you back if you dont mind me asking?
i might get one but i dont think i could because of the way the memory slots are on my motherboard?
Theyre not in line :P
you think one would fit?
Danny nice mate!!!
unless you run your memory way out of spec then they arent necessary. for ram like mine, that i change from ddr800 to ddr1200 regularly, its kind of important to have lots of cooling.
I was bored today and instead of starting my homework I decided to work in some cable management! :D
BEFORE:
AFTER:
So, what do you guys think?? :)
It has some LED's on the front panel, the power indicator looks nice in blue. On the side panel it looks like this:
Except the led fan comes on the left panel and on the back it's just a regular black fan.
But I changed them around. Removed the side fan and put it in the back and put the back fan in the front. Confusing!? :P
I like that Ramodk.. Not bad at all. I have a wholesaler trying to pitch me on the RAM with LEDs on them.. I couldn't really imagine why anyone would want silly little lights on RAM... but seeing them in your case they do look neato.
Personally I think the HSF is the weak link there. Everything else looks tricked out, but the HSF is so plain and kinda ugly. Have you thought of putting a fancier unit in it's place?
Danny nice mate!!!
I don't think it'd work, Shane. Sorry man. You can allways stick a fan near them?
I love the way your case looks from the front Kornowski !
Thanks :D
Complete blue+green party up in there Danny, nice! :D
Haha, Totally! ;)
yeah i seen a pic in here somewhere that a member made their own like stand which went over the memory with a fan on top.
suppose i could but theres not much room with that Heatsink by the Cpu and plus the AC7 pro
Nice memory cooler danny, i bought the same one and used it for a little while. But my ram slots are too close to my video card, making the metal on the fans nearly touch my graphics card :eek:
Ah well, i cut one of the fans off and used it on my north bridge :P
Thanks, Corey! I remember seeing that, Yeah.
I've got a little gap! I was going to put some foam in there, but it wasn't worth it...
do you personaly think it would be worth doing?
i havnt realy oc my ram that much :D
I guess it can only help... Right?
Nothing bad would come of it! :P
