im sorry to hijack the post but i might aswell ask it in here save starting another post.
can bad Bios updates render you motherboard useless? i heard that it can
my motherboard has this software which downloads the latest bios and installs it within windows but i dont trust it![]()
Yeah, You can brick your MOBO updating the BIOS. Also, I wouldn't do it through Windows. Best to do it off a bootable Floppy, CD or USB.
I'd only update the BIOS as a LAST resort!
if it is that risky, i won't try. It's just that my bios is probably 4 years old at least, and the only overcloking options it has is to raise the multiplyer. And without raising the voltage, I can only get my cpu from 2.5 to 3.0. Oh well...
Well... I don't think it's all that risky doing it out side of Windows. Maybe in Windows it is a little. I've never updated a BIOS... My BIOS is maybe, 1 year old.
I'm not sure if a new BIOS will give the motherboard more OC'ing features, look into it before you do it, know what you want and what you'll gain from flashing it.
Hope this helps!
Oh, and 500Mhz aint a bad OC![]()
