Bros Comp
NerdyMatt
Thanks for replying to my other comp build guys i got tones of useful info from your replys:D!, im just building one for my bro at the moment im not to sure on some of the parts:( but if i could get your help that would b awesome
Q6600 2.4ghz
XFX NFORCE 680i or 780i --> money is a concern but i dont really see any big differences between these boards.
PSU Silverstone 500w Strider--> i think itll run on a 500w psu
2x2gb Corsair ddr2 800
Antec 900 Gaming Case
Asus 22inch LCD
Leadtek 8600gt 512mb DDR3---> not to sure on vid card either but i can get it really cheap
Standard mouse,kboard, and dvd drive
750gb Sata 16mb harddrive
Thanks in advance for replys:D
-Matt
Looks good... maybe a different motherboard....
What is your budget???
What is the use of the computer mainly for?
the budget is around $1500 but its australian. With them parts i posted above it sits around 1400-1500.
He'll be using for moderate gaming(counter strike, wow) but none of the new games
thanks
thanks
OK.... maybe a different Motherboard, and the 8800GT for the video card otherwise i think it should be good...
what OS?
Will you run SLi set-up?
If no, just get a cheap P35 Mobo.
If yes, you'd probably get a more powerful PSU, like 650W - 700W
For GPU, 8600GT DDR3 is not really a good gaming card.
Get a 9600GT/ 8800GT 512MB
Ill just be running XP
Yeah i was thinking of getting a 8800GT instead..
What motherboard would use recommend instead of the 680i?
It wont be using SLI
thanks
