jaysstandish
Ok guys I promise that this will be my last thread reguarding my build!
ok so I decided on NOT buying a new case because it didn't make sense to buy a whole new one and risking the chance it wouldn't fit my motherboard so the case is out of the option. I decided on the 8800 GS because I can overclock it with Ntune and it is good value for the money plus it comes with cod 4
. Heres the link to it
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150294
Since I'll have that graphics card replacing my 8500 gt I will need a larger PSU so I'll be upgrading from some random 350 watt HP came with to a 550 watt rosewill or should I get the 500 watt rosewell? Heres the 550 watt I was planning on getting
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182017
Ok so those are the two parts that I will be hopefully purchasing. The 8800gs should connect via the 6pin connector for the extra power with the rosewell (The 550 has 1 6 pin and the 500 has 2 wtf?) Ok and my last question is since it is an HP Pavilion Elite d5000t ATX series with a random 350 watt PSU will my new rosewell be able to fit into it????? ok well thanks for any responses.
-jay
-jay
