Virtual Memory
Guys, if you don't know how to do it then don't post. Cohen, he is talking about virtual memory, not physical memory.
To the OP, to increase the size of the page file go to Start > Right click on "Computer" > Properties > Advanced System Settings > Click on "Settings" under Performance > Advanced > Click "Change" under Virtual Memory
  1. Go to start
  2. right click on computer
  3. go to properties
  4. go to advanced system settings
  5. go to the advanced tab and click on settings listed under performance
  6. click on the advanced tab
  7. click the change button
  8. click on custom size
  9. make the minumum size equal to the current allocated size and the max to
whatever you want
warning* increasing the use of your virtual memory can increase your performance but it will also use your hard drive each time its utilized.
  1. Go to start
  3. go to properties
whatever you want
I already said the same exact thing before you.
Doesn't Windows define virtual memory = physical + paging ?
Then more physical ram will also increase the virtual memory counter.
Virtual memory is just that, virtual. What you may be referring to is the size of the virtual memory, as it does get larger/smaller with the amount of physical RAM that is installed.
Right click on my computer > Advance tab > performance settings > advance tab > here you will get settings for virtual memory settings
