OK, thankyou
Here are some instructions:
To configure Outlook 2007 for your Gmail address:
1. Enable POP in Gmail. Don't forget to click Save Changes when you're done.
2. Open Outlook.
3. Click the Tools menu, and select Account Settings...
4. On the E-mail tab, click New...
5. If you are prompted to Choose E-mail Service, select Microsoft Exchange, POP3, IMAP, or HTTP, and click Next.
6. Fill in all necessary fields to include the following information:
Your Name: Enter your name as you would like it to appear in the From: field of outgoing messages.
Email Address: Enter your full Gmail email address (
[email protected]).
Password: Enter your Gmail password.
Manually configure server settings or additional server types: Leave this option unchecked if you want to automatically configure Outlook 2007. If you want to manually configure Outlook 2007, check this box now.
7 Click Next. If you are configuring Outlook 2007 automatically, you're done! Just click Finish.
8. If you are configuring Outlook 2007 manually, select Internet E-mail and click Next.
9. Verify your User Information, and enter the following additional information:
Server Information
Account Type: POP3
Incoming mail server: pop.gmail.com
Outgoing mail server (SMTP): smtp.gmail.com
Logon Information
User Name: Enter your Gmail username (including @gmail.com).
Require logon using Secure Password Authentication (SPA): Leave this option unchecked.
10. Account Settings Click the More Settings... button, and select the Outgoing Server tab.
11. Check the box next to My outgoing server (SMTP) requires authentication and select Use same settings as my incoming mail server.
12. Outgoing Server Tab Click the Advanced tab, and check the box next to This server requires an encrypted connection (SSL) under Incoming Server (POP3).
13. In the Outgoing server (SMTP) box, enter 587, and select TLS from the drop-down menu next to Use the following type of encrypted connection:.
14. Advanced Tab Click OK.
15. Click Test Account Settings... After receiving Congratulations! All tests completed successfully, click Close.
16. Click Next, and then click Finish.
Hope this helps, if this is a problem go to
this website
Congratulations! You're done configuring your client to send and retrieve Gmail messages.
