ok I want to build a file server with 10TB of disk space .. now i've jst been coming across a few issues ..
OK i'm obviously gona be using 10 1TB hdd's I have a hookup which they can get them for me 50% off (yay) 130 nzd or so (so like 80ish usd)
A) how do i fit them all into a case and also have fans blowing on them.. as they'll be stacked above each other which will generate a bit of heat ..
the bottom ones will most prob have a fan slot for it .. but i'm guessing i'll have to use some 5.25" bays .. which generally doesn't have fans directed at them
B)what mobo fits the most sata connectors .. and I also understand i'll prob have to use a pci-x sata controller or something ..
C) is there a way which i can use JBOD interchangingly(if thats the right term) between 2 controllers .. cause i just want it to look like 1 giant harddrive .. so I don't have to go through like 10 HDD's to find stuff
