12v rails are driving me nuts, power supp. question
xXxRuinationxXx
ok
so yea you can see my pc from my other post
I'm running tri sli 512 ddr3 9800 black edition pci-ex's
requiring 26a on the 12 v rails
this is the power supply I just ordered, will it suffice?
Kingwin Mach 1 1000W Power Supply Modular Cables 20/24PIN SLI Ready
DC OUTPUT
Output Voltage +3.3V +5V +12V1 +12V2 +12V3 +12V4 +12V5 +12V6 -12V +5
Max. Load 24A 30A 20A 20A 20A 35A 35A 20A 0.5A 5.0A
Min. Load 1.0A 1.0A 0.8A 0.8A 0.5A 1.0A 1.0A 1.0A 0A 0.1A
Regulation ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±10% ±5%
Ripple & Noise(mV) 50 50 120 120 120 120 120 120 120 50
Total Power 1000W continuous output @ 50C ambient temperature
xXxRuinationxXx
ok now what about this one
XFX DDR3 GX2 9800GTX black edition at 40a draw
with three of those on a
Kingwin 1000w ABT-1000MA1S
4x 20a rails
2x 35a rails
pass or fail?
hermeslyre
Any decent 500-600w PSU can handle the GX2. Anything above is more than enough, case in point either of those units.
Edit: oh. Three. Wow. :p
hermeslyre
Both that I need to learn how to read and yes, they're both fine for your purposes.
EDIT: assessment is taking into account the fact you can only SLI 9800gx2, not tri-sli it.
1Kurgan1
4x 20a rails
2x 35a rails
pass or fail?
Just count the amps, you already got them all there. 40xA x 3 = 120A
20A x 4 = 80A + 35A x 2 = 70A for a grand total of 150A. Won't quiet have room for a forth. Either way I would suggest not going with 3x 9800GTX's. No mobo on the market has 16x PCI-E for that 3rd slot. It would be more benefical to pickup a 9800GX2, save a little cash and pickup another 9800GX2 a little down the road.
I don't know about a GX2... If I'm thinking right that should take over 50A and most PSU's don't make over 20A on a 12V line, especially ones of lower wattage. So you would want to look for a 3 line 12V PSU and those start to get a little more pricey.
hermeslyre
GX2 has a 40a req., giving a quality 500w unit enough power to support the *required spec* GX2. In reality you might not even see a 40a draw under load, req specs are always generous.
You can find units that don't have the 20a per single Rail limitation, I would advise a single rail unit over any multi-rail, because of the dependent, trapped power with multi-rail PSU's, E.G. If you have a 3 line unit, one of those lines would be dedicated to the CPU, giving you only two lines for the GPU-HDD's-etc.
1Kurgan1
Wow 40a only, I would have expected more, heck my old x1950 Pro wanted 28a. I would agree a single line is better, but I don't know of a PSU with a single line rating of 40a. Very few PSU's cross 20 on single lines.
