Archangel
First of all,.. my HDD temps are rather concerning me,.. its fitted right behind the 140mm intake fan in the front
Pic:
yet the temperature indicated by Everest is 50*C ( my motherboard isnt supported anymore by everest.. but the HDD is recognized by it
(it says its a WDC WD2500JS-55NCB1 ) Edit: as the name does suggest, its a 250Gb Western digital HD ( 7200rpm, but im not sure weither its 8mb or 16mb cache. :x )
so im wondering.. is 50*C a normal temp for a HDD, or is something wrong?
the second question,.. I can buy a 36Gb Raptor rather cheap, If i get it, can i copy my current C:/ partition to it, so i dont have to reinstall windows,. and If i do that, would it make a significant difference?
Pic:
