Build parts
What sort of games is he intending to play?
Does he need an OS?
It is a very tight budget for gaming. :/
He understands this and he will run games on low settings and won't be running games like crysis and cod.
Okay does he need an Operating system? because windows 7 that's like £73 on its own.
Hows this,Slightly over budget at £332.02 but i think thats the best your going to get for the money and to be able to play games smoothly.
AMD Athlon II X4 640 Socket AM3 3GHz 2MB L2 Cache Retail Boxed Processor
http://www.ebuyer.com/product/242140
MSI 880GM-E41 880G Socket AM3 onboard graphics 8 channel HD audio mATX Motherboard
http://www.ebuyer.com/product/244433
Kingston 4GB (2x2GB) DDR3 1600MHz HyperX Blu Memory Kit CL9 1.65V Non-ECC Unbuffered
http://www.ebuyer.com/product/234975
Gigabyte GTX 550 Ti OC 1GB GDDR5 Dual DVI Mini HDMI PCI-E Graphics Card
http://www.ebuyer.com/product/260567
Samsung SH-S223 22x DVD±RW DL SATA Optical Drive - Retail Box Black with Software
http://www.ebuyer.com/product/179014
Corsair 600W CX PSU - 2x PCI-E 6x SATA
http://www.ebuyer.com/product/241000
Coolermaster Elite 330 Black Mid Tower Case
http://www.ebuyer.com/product/127584
Amazing build.
Man stuff is expensive in UK. :D
This will also run games like crysis and COD but not maxxed out.
And if your friend also need a monitor in that budget then it is going to be really hard since 300GBP for a gaming tower itself is difficult to build.But Shane here has done an amazing job. :good:
Ive just noticed i had not put in a hard drive for that build,So thats another cost to add,Unless Mark4_4 your friend can use the Harddrive from his current pc and use it for this new build.
EDIT-Revised build. (Still £65 over.)
How about trying out the 500W Builder series PSU.
and 1333MHz memory.That will lower the prices.
Don't know much about prices in UK.
Still the build would be worth the difference and the HD5830 is a great card.
thanks for the help
Hi I am marks mate ryan.
I would like to thank you for all your hardwork sorry for the tight budget.
I would like someone to find me a wireless network card that fits this
thanks make sure its wireless.
I thank you my friend.
You have helped so much I have put up the budget a bit.
and I all most have the right amount.
Thanks again.... :)
I will my friend. I have to save a bit more then I will buy parts. then post pictures
thanks again
I did not need a super one because I do not play very many high graphic games.
I play minecraft Oblivion morrowind and fallout. and a couple of steam games.
