Building a pc inside of an xbox 360 case and need help finding stuff!
ok, cant wait to see it happen, ill post pics of my build that i'm gonna do before my xbox mod when i start if you wanna check it out :D
I definitely am, we should keep each other posted. I figure the system will take me about 8 hours to build and prep, this includes installing the os and actually modding the case!!
So i may have hit somewhat of a snag in my project so i will be shelving it until i have more funding for it, i have concluded the cost of doing this to be higher than i thought and the amount of modding needed would be far too high for my specific abilities. I have decided instead to work on another computer that need a serious upgrade!
So if you want i am willing to mail off the case to you so you can try it out, free of charge except you gotta pay the shipping which will be flat rate!!!
I have also determined that cooling would be a critical issue without major modification or using an Xbox original casing which i don't have!!
