Difference between Operating Systems
What are you talking about? Linux and MacOS are both based on Mach 3.0. Mach 3.0 is based on BSD, which is based on Unix. They're completely related.
Dude what. Stop talking nonsense.
No. Linux is not based on Mach. Linux started off as an independent project from ground up, and no significant portion (if any at all) of the code is based on any existing Unix codebase. And even if were (which it is not), it still doesn't change the fact that Mac OS is *NOT* based on Linux in any sense of the word.
And I'll ask once more, what was the point of the wikipedia article you linked to? Did you have one or do you just link to random stuff pretending that you have a point?
Well for some people its usually a matter of taste. like for example I prefer the windows OS because its compatible and easy to use and simply I'm more used to it. Mac OS are great for security and have very few bugs but it takes getting used to in my opinion. Also windows is cheaper than most other OSes out there. I haven't had much experience with Linux OS but I hear great things about them when it comes to gaming rigs and uses in laptops.
Good Lord your grapping at straws is getting lame.
MkLinux is a 10 YEARS OLD DISCONTINUED FORK OF LINUX THAT HAPPENS TO SHARE CODE WITH MACH.
Linux is NOT MkLinux.
Linux is NOT based on Mach.
MacOS is NOT based on Linux in any way at all.
Either you are horribly misinformed of the history of Unix/Unix-like systems or you're just googling stuff up as you go, trying to save face. Either way, you lack of knowledge is coming through.
EDIT: I just noticed you just screendumped that image. Mind giving a Link to the complete image?
Linux isn't the best option for gaming. Not many games work with it, though that being said, you can now get Steam on Linux.
It's just a matter of familiarity though. If you're used to Windows, you tend to stick with it. If you're used to Linux, you tend to stick with it - and the same goes for OS X. It's good to try new things though. You never know, you may like something different.
The best way to put it is that if you dual boot Windows and Linux, there is nothing that you will not be able to run.
For most though, your ability to learn Linux is only limited by your ability to google. It is not in any way difficult to use, unlike windows in my opinion.
Yes, Mac OSX uses BSD/Mach.
http://support.apple.com/kb/ta25634
Linux has nothing to do with BSD. Both BSD and Linux derive ideas from Unix, but that doesn't mean Linux=BSD.
If you think Mac OSX is based on Linux you're misinformed.
Linux is Linux because if it's kernel and the GNU coreutils. Last time I checked, BSD had it's own kernel and own utils. Linux!=BSD. OSX!=Linux
I'm agreeing with hackapelite 100% on this one. You're understanding of all of this is wrong.
Go to a BSD community and try and say Linux and BSD are the same and you may find your computer hacked and wiped clean. Linux and BSD operate similar in how they do things but they are different. They both have a monolithic kernel but they are different kernels in terms of the code in them, they have different file systems as in what is there and where they are located and operate differently in security. Linux (Unix Like) BSD (Unix).
You are also right about Windows being faster, this is through greater system resource usage, which depending on your hardware or what you do this may not be a big deal but if your trying to get a lot done on a everyday laptop like mine lower usage is important. So keep your speed and I will keep my multitasking and security, haven't had a infection in over five years of using Linux no matter what I do on the web.
Ease of use is a matter of opinion.
I don't know about that. It's faster at some things, but I haven't seen Windows consistently beat Linux except in gaming/3D benchmarks where Linux is held back by crappy video drivers. Everywhere else, it's mostly a mixed bag, usually coming down to specific configuration (choice of filesystem for a given task, kernel latency and whatnot), but I haven't seen either OS soundly beat the other at anything when it comes down to raw performance (not that these cases don't exist, though, I imagine they're pretty uncommon).
I did.
This is what they have say at freebsd.org
So what is really the difference between, say, Debian Linux and FreeBSD? For the average user, the difference is surprisingly small: Both are UNIX® like operating systems.
and here
There is an old saying about BSD vs. Linux: “BSD is what you get when a bunch of UNIX hackers sit down to try to port a UNIX system to the PC. Linux is what you get when a bunch of PC hackers sit down and try to write a UNIX system for the PC.” That expression says a lot. What you will find is that the BSDs are much more similar to UNIX because they are, in fact, direct derivatives of traditional UNIX. Linux, on the other hand, was a newly created OS loosely based on a UNIX derivative (Minix, to be exact).
Then on to the Minix wiki, where it says
MINIX is a Unix-like computer operating system based on a microkernel architecture created by Andrew S. Tanenbaum for educational purposes; MINIX also inspired the creation of the Linux kernel. ...It has been free and open source software since it was re-licensed under the BSD license in April 2000
Wow they're completely unrelated. Even at the Linux Mint wiki, it describes BSD in its antecedents list. This means family. It also means BSD has been around longer.
Furthermore:
Linus himself said:
...that if 386BSD had been available at the time, he probably would not have created Linux.
It is in no way clear cut like that. The core of the comparison and answering the OPs question about the differences about OSs, the MacOS and Linux will be much more similar than Windows.
I do still maintain that there is so much more common in design etc between MacOS and Linux than with Windows.
Practially the difference is minimal. They'll run the same programs and some drivers etc.
You're still clutching at straws.
Your claim was that Mac OS is based on Linux. That's plain wrong. Nobody here ever argued that Mac OS isn't more similar to Linux that Windows. Linux is classified as "Unix-like" (or *nix) for their similarities and even said that earlier. The old quote doesn't prove anything; it's a joke. It's like saying Windows is an unstable, crash-prone piece of garbage and then quoting the Gates and GM CEO conversation as a proof.
Wow they're completely unrelated.Even at the Linux Mint wiki, it describes BSD in its antecedents list. This means family. It also means BSD has been around longer.
Brilliant, now we're equivocating too.
I meant "unrelated" as in "not based on". Given the context and how I said that they have no common code base or ancestry, that should have been obvious. I never ever claimed that they are completely "unrelated" in the sense that they have no common ideas or influences. I already referred to Linux as a "Unix-like". NyxCharon said that both BSD and Linux derive ideas from Unix. DMG said that linux and BSD operate similar. Nobody's keeping it a secret, much less ignoring it, even less still disagreeing with it. We all agree with that. Yes, all "Unix-like" system share some basic ideas and concepts and are in that sense related; that's why they're called Unix-like. That doesn't change the fact that Mac OS is not in any way based on Linux.
And yes, Linux was loosely based in Minix, which is derivd from Unix. Note, though, that both "based" and "derived" here are used in tho context of "sharing common ideas and concepts"; they were both independently developed from ground up with vastly different goals in mind and with vastly different architectures / implementations (such as microkernel vs monolithic). Again, though the wiki of any one distro isn't an authoritative source on Linux in general, the fact that BSD is an "antecedent" means more or less the same - they share a fair bit of philosophy and ideas, and they are in the family of "Unix-like systems". I say again, nobody has denied this (and not all members of this "family" share a common ancestor).
And yes, Linus did say that. He created Linux out of need for a fast, free Unix-like system for his 386; if there had been one (e.g. 386BSD), he wouldn't have made his own. Not a very informative statement. It doesn't really said much at all about Linux's relation to Unix/BSD; it definitely doesn't say anything at all about Mac OS being based on Linux.
It sounds as if you are implying that someone here has argued against that; nobody has, and please let the goal posts be. If you didn't mean to imply that, please accept my apologies and let me just say that I'm glad you maintain a position just about every Linux user who has posted in this thread so far also maintains.
In practice, there are significant differences to an everyday user; even for power-users who work beneath the hood (where the most commonality acress Unix-like systems is; the specs and philosophies have little relevance to an everyday user who doesn't care which one of bash or dash implement the more standard-compliant echo) there are numerous non-trivial differences. They run some of the same programs, sure, but in just about all cases any non-trivial programs have to be ported; at which point you might as well say that Windows runs all the same programs too, since they either have been ported to Windows or can be compiled against cygwin (which also, by the way, allows you to run a full GNU userland and just about any Linux application natively under Windows [which, ironically, you can't do with Mac applications]; does that make Windows "Unix-like" too?) The differences for drivers are even greater; at least one of the current BSDs (I forget which one) can run Linux drivers with a compatibility layer, but the driver binary interfaces (and consequently, drivers themselves) are quite different. You won't ever be running the same driver natively under a BSD and a Linux system.
And though I hate to pester you about this, would you (pretty please?) tell me what point the wikipedia article to a mental disorder was meant to make, and why did you post a cropped screenshot of a picture of *nix ancestry as opposed to, say, the original?
Yup I'd just go with windows. They are just better over all when it comes to coustom builds and over all compatibility.
hack, im not clutching at any straws, but simply quoting others. Linus, Linux and BSD all recongnise each other as related. Not me saying it.
Im simply saying in terms of genesis, the OSs are very much more related than they are to Windows.
Ive simply produced evidence for my view.
Anti, chill, the OP will come back when he or she is ready, sometimes never, it happens, dont die in a ditch over it. :)
You're right, but when you get abandoned threads they usually end up going off in a tangent about the topic. If the OP comes back, he or she can fill in the gaps.
