First PC Build & Over Budget----NEED HELP
Discussion in 'Desktop Computers' started by Newfiestang50, Nov 29, 2016.
  1. Newfiestang50
    Newfiestang50 Member
    134
    Well as the title states I am trying to put together a list of parts to build my first PC and its to be a gaming PC. Now just to be clear, I am by no means versed in all the details of the PC building world thus any advice no matter how minor please dont hesitate to suggest changes. I kind of copied the build from another thread on here and all components are from NCIX Canada.
    Also, I am way over budget as my limit was $1500 CDN but the components below are approaching $2000 and i still dont have Windows 10 added yet. If anyone can suggest changes that will reduce my cost to within budget it would be appreciated.
    PC Components:
    http://www.ncix.com/detail/intel-core-i5-6600k-3-50ghz-6m-e0-110591.htm?promoid=1805
    http://www.ncix.com/detail/evga-geforce-gtx-1070-sc-f3-132464.htm?promoid=1714
    http://www.ncix.com/detail/gigabyte-z170x-ud3-ultra-lga-a6-133204.htm?promoid=1957
    http://www.ncix.com/detail/fractal-design-define-r5-atx-70-102216.htm?promoid=1714
    http://www.ncix.com/detail/corsair-cx-series-cx650m-650w-d4-125719.htm?promoid=1714
    http://www.ncix.com/detail/g-skill-ripjaws-x-16gb-2x8gb-25-73133.htm?promoid=1714
    http://www.ncix.com/detail/western-digital-caviar-blue-1tb-87-74462.htm?promoid=1714
    http://www.ncix.com/detail/samsung-850-evo-mz-75e250b-am-250gb-67-120450.htm?promoid=1714
    http://www.ncix.com/detail/cooler-master-hyper-212-evo-6a-64385.htm?promoid=1714
  2. AMD_man
    AMD_man Member
    109
    If you want to reduce your budget you could get a GTX1060. Not too much performance loss, but no SLI. Everything else seems standard.
  3. Laquer Head
    Laquer Head Well-Known Member
    6,226
    Asus Dual 1070 and Black Ed. EVGA Sc 1070 are both 529 on newegg.ca so thats 20-30 saved right there without dropping from a 1070
    Same with the mobo, drop to a gigbyte g1 or msi m3 on newegg..both are $25ish less..
    if you need to, drop to a single 8GB ram stick, or better 4GBx4GB and save there too.. all these little concessions will pay towards the o/s
  4. AMD_man
    AMD_man Member
    109
    Hey your RAM is DDR3. Just noticed. That´s not compatible with your motherboard.
    Also in the spirit of savings without downgrading you could get a cheaper motherboard and case:
    https://ca.pcpartpicker.com/list/GWVcGf
  5. Laquer Head
    6,226
    Yeah good call on the RAM.. didn't even notice that. Certainly need DDR4!
    Newegg was doing an intel cpu/windows o/s combo bundle thing just before the weekend...not sure if thats still on..
    The 6600K was one of the cpus listed!!
    just need a ssd, assuming he still wants one.. other than that your really skimping on parts..thats pretty close to 1500$
  6. Newfiestang50
    134
    Can someone tell me what the difference is in SLI and PCI-E.
  7. Laquer Head
    6,226
    PCI-E is the bus you connect a device to, SLI is a technology for link 2 or more graphics cards together..
  8. Newfiestang50
    134
    So with this part picker toll and AMD Mans post is this total in CDN $$
  9. Laquer Head
    6,226
    Yes, @AMD_man linked to the .ca version and I'm also in Canada, yes this is CDN$
    obviously there is still provinical taxes and shipping costs to factor in over and above.
  10. AMD_man
    AMD_man Member
    109
    An SSD sounds good, but that would be up to him I guess, keeping in mind that an SSD would be making the budget at least $100 more expensive.
    I don´t know if the budget looks good now.
    Original: https://ca.pcpartpicker.com/list/dFd92R
    Now: https://ca.pcpartpicker.com/list/CccbTH
    Don´t really see much difference.
    If you really want to reduce your budget you are going to have to swap GPUs or CPUs.
    I didn´t understand what you meant by that. Did you mean that the price didn´t change much?
  11. Newfiestang50
    134
    Ok well I can say that I have no intention in getting that serious with gaming so can you guys recommend some good quality non SLI components.
  12. AMD_man
    AMD_man Member
    109
    GTX-1060 right now is one of the most cash efficient units. The only thing is that it has no SLI. If you still feel it´s too much you could go for the 1050 or the 1050ti.
  13. Laquer Head
    6,226
    Just don't buy a second graphics card...boom ...no SLI
    I'm wondering if you even need a K-series CPU. If your not into overclocking just get a normal, locked version...save money there too!
  14. Newfiestang50
    134
    Sounds good, I definitely wont be overclocking either....so I guess thats the difference of the 'K' designation. So based on that, should I stay with an i5 or should I move to an i7.
  15. Laquer Head
    6,226
    Honestly grab a non-K i5, and go to a gtx 1060 with 6GB and I think thats a better focused build for you. With the GPU savings, you could throw in that SSD for the operating system..
    I think the K-series CPU and 1070 is too much for your needs and its putting you past your budget for no reason.
    Maybe @AMD_man would mind making a revised partpicker build with these changes and a new total?
    AMD_man likes this.
  16. AMD_man
    AMD_man Member
    109
    If it´s just for gaming, I5. And like @Laquer Head said, get the 6Gb version of the 1060.
    Missed that.
    https://ca.pcpartpicker.com/list/kRjZ9W
    Note that some are from parametric filters. Not bad choices, but you can dance within those specs and have no issues.
    PS: It´s been fun using the Canadian page. Every time I look for an item I get shocked because of the prices and then remember it´s the Canadian version of the page. Nuts.
    Laquer Head likes this.
  17. Newfiestang50
    134
    I've updated AMD man's build but there are a few compatibility notes at the bottom of the build, please take a look and let me know if these are a real concern.
    - I didnt downgrade the processor as I really didnt see no big price drop by going down to a non 'K' processor.
    - Changed the GPU to a non SLI GTX 1060 but there are a few there to choose from hopefully what I selected is ok.
    - Will I need an network adapter, I assume yes so please help me select a suitable card.
    - I added Windows 10 Home, can someone please give me the basic difference of the PRO version.
    I will need a CD/DVD drive, a suggestion on this as well would be appreciated.
    Also, is there anything else needed for this build, I have a monitor, keyboard, mouse, etc from my old Dell so i assume that will still work fine. I do plan on upgrading those devices later.
  18. Newfiestang50
    134
    I've created an account in pcpartpicker but how do i copy my build here for all you guys to see without sharing my login info. I assume if i past the link here from my build its going to prompt you to log in.
  19. AMD_man
    AMD_man Member
    109
    There is a thing that says "permalink".
    Paste that link. No need to login for us.
  20. Newfiestang50
    134
    Ok....got it. That site is great if you know what parts you are looking for lol.
    https://ca.pcpartpicker.com/user/Newfiestang50/saved/NRJMpg
    Also, as mentioned in previous post
Share This Page
