ok but what is the difference between normal router and dedicated one ?
ZAX0L New Member Mar 5, 2014 #21 ok but what is the difference between normal router and dedicated one ?
johnb35 Administrator Staff member Mar 6, 2014 #22 You don't have a normal router, you have a modem/router combo unit meaning they are built in together. Trying to use that as second router will be hard.
Cromewell Administrator Staff member Mar 6, 2014 #23 It should still be fairly simple to do. Modem/router/switch or router/switch with dedicated modem. Just use the switch ports, not the ADSL/WAN one.
