I need help with my PC(need better gaming experience)
What is your existing spec?
With G965/ P965 chipset, you could upgrade to C2D/ C2Q CPU with a decent Video card and PSU. That would make a decent machine.
this is my current spec:
System Information
Time of this report: 6/13/2010, 18:22:29
Machine name: DANILO-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language: English (Regional Setting: English)
System Manufacturer: HP Pavilion 061
System Model: RC649AA-ABA m7684n
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Genuine Intel(R) CPU 2160 @ 1.80GHz (2 CPUs), ~900MHz
Memory: 3072MB RAM
Available OS Memory: 3070MB RAM
Page File: 1413MB used, 4725MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 7300 GS
Manufacturer: NVIDIA
Chip type: GeForce 7300 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_01DF&SUBSYS_22001682&REV_A1
Display Memory: 1528 MB
Dedicated Memory: 249 MB
Shared Memory: 1279 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LW98
Monitor Id: AOC1982
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: HD15
Driver Name: nvd3dum.dll
Driver File Version: 8.16.0011.9107 (English)
Driver Version: 8.16.11.9107
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 9/27/2009 23:12:22, 7614056 bytes
WHQL Logo'd: Yes
daisy, if u think i can upgrade my pc without buying another one and comming out cheaper for me, please go on, bring out your ideas. but if its going to cost me around 500$ total upgrade, at the end is much better if i buy one of this desktop in this website:
http://www.newegg.com/Store/SubCate...sp=computerstore-_-flashstorefront-_-desktops
honestly would recommend a dell/alienware as long as you can get like a 3 or 4 year warranty on it, i dont trust the other brands as they may not offer the support dell can. have a friend with a xps 630i and had the warranty...something failed, within the week had a tech down, replaced the mobo, fans, and power supply...that paid for the warranty right there.
so in sum of everything, if you dont want to eff with it...get a good warranty to back the damn thing up.
Can someone give me an estimate of about how long it would take to build a computer with everything you need right in front of you?
Can someone Recommend me a decent PC please? :s i have speakers, mouse, and monitor(kind of).
Budget is below 1200$. With good graphic card and Processor. Im a gamer.
Anyone that can help and point me to the right direction ill really appreciate it.
OP, where are you located so we can consider where you would buy from.
Edit, only saw the first page.......
Dominican republic,santo domingo.
NEW: I'm going to have to lower my budget. 500-750$. I'm looking for a cpu capable of running most of the games in a decent high resolution. Please any recommendation or help is welcome.
I'm only looking for a cpu.I have monitor,speakers,etc...don't recommend me piece for me to built them. Thanks.
You only need a CPU? Do you mean like the tower? The CPU is a chip on the motherboard, and it sounds like you don't have any of that.
