OvenMaster
On the Setup page, mine says this: Firmware Version: 2.00.1, Sep 11 2006
After I did what I posted above, I'd have to say it's now flawless. Bulletproof. Fast. It actually runs cooler than when I had problems! I hope it outlives the warranty, because I practically have to force it to lose a connection. Even with a second PC using it at the same time, I have zero complaints.
In short, I think it was well, well worth the $40 I paid for it. Highly recommended.
I have Verizon 768/128 DSL, and here's what my results are with Speedtest:
Tom
PS: One other thing. Sometimes if a lot of people are using the same cable "node" that you are, your connection speeds WILL drop. The more that use it, the slower you'll be going. You probably will have a Static IP and Default Gateway assigned by Comcast... chances are that you will NOT have PPPoE as used by DSL, as shown in the pic I linked to up above... but if you're working okay, then I'll just shut up now![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](http://www.speedtest.net/result/167046320.png)
Tom
